Hi,
we have 3 sites in Netlify
all of them using the same repo
1.production
2.staging
3.storybook
we added CSP headers to toml file
but we have a problem with the eval function
we don’t allow it in production and staging sites but need it in the storybook site
there is a way to control the headers dynamically by the sites
Hi, @yotav_masa, one solution is to modify the _header or netlify.toml file during the builds with a site specific build command.
For example you can have three different _header files like so:
site1-headers
site2-headers
site3-headers
Then for each site you can change the actual headers file as part of the build. For example, (using a build.publish setting of my-publish-directory) if the starting build.command is npm run build then the new build.command for site one would be:
cp site1-headers my-publish-directory/_headers && npm run build
This is only one of many options. For example, you might make the updating the _headers file part of the node build command itself instead of a separate command before it.
