I’m building with puppeteer (I scrape a site for the latest content, which is then integrated into the build). It was working a few months ago, but I checked on it today and it seems to be failing to start Chrome.
I’ve tried a few things without success. The official troubleshooting guide hasn’t gotten me anywhere and searching only pulls up advice for using puppeteer in functions, which isn’t useful for me.
Troubleshooting guide: https://github.com/GoogleChrome/puppeteer/blob/master/docs/troubleshooting.md
Error message: Error: Failed to launch chrome!
FWIW, I’m using node 12.14.0.
The last successful build was on October 10. I have daily builds setup with zapier and none of them have worked. I have also been troubleshooting and rebuilding without success this evening.
Successful Log:
10:51:11 PM: Build ready to start
10:51:27 PM: build-image version: 9e0f207a27642d0115b1ca97cd5e8cebbe492f63
10:51:27 PM: build-image tag: v3.3.2
10:51:27 PM: buildbot version: 8727aab446158e7b8c8ad2e96fe74b0154505a4e
10:51:27 PM: Fetching cached dependencies
10:51:27 PM: Starting to download cache of 99.1MB
10:51:28 PM: Finished downloading cache in 866.127886ms
10:51:28 PM: Starting to extract cache
10:51:32 PM: Finished extracting cache in 3.7840482s
10:51:32 PM: Finished fetching cache in 4.707412073s
10:51:32 PM: Starting to prepare the repo for build
10:51:32 PM: Preparing Git Reference refs/heads/master
10:51:33 PM: Starting build script
10:51:33 PM: Installing dependencies
10:51:33 PM: Started restoring cached node version
10:51:36 PM: Finished restoring cached node version
10:51:37 PM: v10.16.3 is already installed.
10:51:38 PM: Now using node v10.16.3 (npm v6.9.0)
10:51:38 PM: Attempting ruby version 2.6.2, read from environment
10:51:39 PM: Using ruby version 2.6.2
10:51:40 PM: Using PHP version 5.6
10:51:40 PM: Started restoring cached node modules
10:51:40 PM: Finished restoring cached node modules
10:51:40 PM: Started restoring cached go cache
10:51:40 PM: Finished restoring cached go cache
10:51:40 PM: unset GOOS;
10:51:40 PM: unset GOARCH;
10:51:40 PM: export GOROOT='/opt/buildhome/.gimme/versions/go1.12.linux.amd64';
10:51:40 PM: export PATH="/opt/buildhome/.gimme/versions/go1.12.linux.amd64/bin:${PATH}";
10:51:40 PM: go version >&2;
10:51:40 PM: export GIMME_ENV='/opt/buildhome/.gimme/env/go1.12.linux.amd64.env';
10:51:40 PM: go version go1.12 linux/amd64
10:51:40 PM: Installing missing commands
10:51:40 PM: Verify run directory
10:51:40 PM: Executing user command: npm install && npm run scrape && cd website && npm ci && npm run build
10:51:47 PM: > puppeteer@1.19.0 install /opt/build/repo/node_modules/puppeteer
10:51:47 PM: > node install.js
10:51:56 PM: Chromium downloaded to /opt/build/repo/node_modules/puppeteer/.local-chromium/linux-674921
10:51:56 PM: npm
10:51:56 PM: WARN r6-scraper@1.0.0 No repository field.
10:51:56 PM: added 19 packages from 20 contributors, removed 963 packages, updated 4 packages and audited 60 packages in 14.997s
10:51:56 PM: found 0 vulnerabilities
10:51:56 PM: > r6-scraper@1.0.0 scrape /opt/build/repo
10:51:56 PM: > npm cache clean --force && node build.js
10:51:57 PM: npm
10:51:57 PM: WARN using --force
10:51:57 PM: I sure hope you know what you are doing.
10:52:06 PM: Added https://game-rainbow6.ubi.com/assets/data/seasons.11bfe9f0.json to manifest list.
10:52:06 PM: Added https://game-rainbow6.ubi.com/assets/locales/locale.en-us.32a22eb2.json to manifest list.
10:52:08 PM: Identified version as v2.3.6
10:52:44 PM: > docusaurus-build
10:52:50 PM: generate.js triggered...
10:52:51 PM: sitemap.js triggered...
10:53:38 PM: Site built successfully. Generated files in 'build' folder.
10:58:16 PM: Skipping functions preparation step: no functions directory set
10:58:16 PM: Caching artifacts
10:58:16 PM: Started saving node modules
10:58:16 PM: Finished saving node modules
10:58:16 PM: Started saving pip cache
10:58:16 PM: Finished saving pip cache
10:58:16 PM: Started saving emacs cask dependencies
10:58:16 PM: Finished saving emacs cask dependencies
10:58:16 PM: Started saving maven dependencies
10:58:16 PM: Finished saving maven dependencies
10:58:16 PM: Started saving boot dependencies
10:58:16 PM: Finished saving boot dependencies
10:58:16 PM: Started saving go dependencies
10:58:16 PM: Finished saving go dependencies
10:58:16 PM: Build script success
10:58:16 PM: Starting to deploy site from './website/build/api-docs'
10:58:17 PM: Creating deploy tree asynchronously
10:58:19 PM: 1 new files to upload
10:58:19 PM: 0 new functions to upload
10:58:19 PM: Starting post processing
10:58:22 PM: Post processing done
10:58:22 PM: Site is live
10:58:39 PM: Finished processing build request in 7m12.022918765s
Failed Log:
12:01:45 AM: Build ready to start
12:06:17 AM: build-image version: 9e0f207a27642d0115b1ca97cd5e8cebbe492f63
12:06:17 AM: build-image tag: v3.3.2
12:06:17 AM: buildbot version: 8727aab446158e7b8c8ad2e96fe74b0154505a4e
12:06:17 AM: Fetching cached dependencies
12:06:18 AM: Starting to download cache of 99.1MB
12:06:18 AM: Finished downloading cache in 1.147576678s
12:06:18 AM: Starting to extract cache
12:06:24 AM: Finished extracting cache in 5.37538485s
12:06:24 AM: Finished fetching cache in 6.553337648s
12:06:24 AM: Starting to prepare the repo for build
12:06:24 AM: Preparing Git Reference refs/heads/master
12:06:25 AM: Starting build script
12:06:25 AM: Installing dependencies
12:06:27 AM: Started restoring cached node version
12:06:30 AM: Finished restoring cached node version
12:06:31 AM: v10.16.3 is already installed.
12:06:32 AM: Now using node v10.16.3 (npm v6.9.0)
12:06:32 AM: Attempting ruby version 2.6.2, read from environment
12:06:34 AM: Using ruby version 2.6.2
12:06:34 AM: Using PHP version 5.6
12:06:34 AM: Started restoring cached node modules
12:06:34 AM: Finished restoring cached node modules
12:06:35 AM: Installing NPM modules using NPM version 6.9.0
12:06:43 AM: > puppeteer@1.20.0 install /opt/build/repo/node_modules/puppeteer
12:06:43 AM: > node install.js
12:06:52 AM: Chromium downloaded to /opt/build/repo/node_modules/puppeteer/.local-chromium/linux-686378
12:06:52 AM: npm WARN
12:06:52 AM: r6-scraper@1.0.0 No repository field.
12:06:52 AM: added 18 packages from 19 contributors, removed 962 packages, updated 4 packages and audited 60 packages in 15.974s
12:06:52 AM: found 0 vulnerabilities
12:06:52 AM: NPM modules installed
12:06:52 AM: Started restoring cached go cache
12:06:52 AM: Finished restoring cached go cache
12:06:52 AM: unset GOOS;
12:06:52 AM: unset GOARCH;
12:06:52 AM: export GOROOT='/opt/buildhome/.gimme/versions/go1.12.linux.amd64';
12:06:52 AM: export PATH="/opt/buildhome/.gimme/versions/go1.12.linux.amd64/bin:${PATH}";
12:06:52 AM: go version >&2;
12:06:52 AM: export GIMME_ENV='/opt/buildhome/.gimme/env/go1.12.linux.amd64.env';
12:06:53 AM: go version go1.12 linux/amd64
12:06:53 AM: Installing missing commands
12:06:53 AM: Verify run directory
12:06:53 AM: Executing user command: npm install && npm run scrape && cd website && npm ci && npm run build
12:06:55 AM: npm
12:06:55 AM: WARN r6-scraper@1.0.0 No repository field.
12:06:55 AM: audited 60 packages in 0.868s
12:06:55 AM: found 0 vulnerabilities
12:06:55 AM: > r6-scraper@1.0.0 scrape /opt/build/repo
12:06:55 AM: > npm cache clean --force && node build.js
12:06:55 AM: npm
12:06:55 AM: WARN
12:06:55 AM: using --force
12:06:55 AM: I sure hope you know what you are doing.
12:07:00 AM: Error: Failed to launch chrome!
12:07:00 AM: TROUBLESHOOTING: https://github.com/GoogleChrome/puppeteer/blob/master/docs/troubleshooting.md
12:07:00 AM: at onClose (/opt/build/repo/node_modules/puppeteer/lib/Launcher.js:348:14)
12:07:00 AM: at ChildProcess.helper.addEventListener (/opt/build/repo/node_modules/puppeteer/lib/Launcher.js:338:60)
12:07:00 AM: at ChildProcess.emit (events.js:203:15)
12:07:00 AM: at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
12:07:00 AM: npm
12:07:00 AM: ERR!
12:07:00 AM: code ELIFECYCLE
12:07:00 AM: npm
12:07:00 AM: ERR! errno 1
12:07:00 AM: npm
12:07:00 AM: ERR! r6-scraper@1.0.0 scrape: `npm cache clean --force && node build.js`
12:07:00 AM: npm ERR! Exit status 1
12:07:00 AM: failed during stage 'building site': Build script returned non-zero exit code: 1
12:07:00 AM: Failed at the r6-scraper@1.0.0 scrape script.
12:07:00 AM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
12:07:00 AM: Shutting down logging, 20 messages pending
12:07:00 AM: npm
12:07:00 AM: ERR! A complete log of this run can be found in:
12:07:00 AM: npm ERR! /opt/buildhome/.npm/_logs/2019-10-11T05_07_00_099Z-debug.log
