Using nic.is with Netlify / setting a TTL of 86400
Hi @luke, could you update the TTL for flother.is too? Thanks.
Hello :slight_smile:
@Luke can you update the TTL for chu.is as well?
Thank you :slight_smile:
Hi, @flother and @chu. Both domains have had the TTL values for the NS records updated now. :slight_smile:
I… love you…
(Thanks a lot and be safe!)
Hi Luke, can you update the TTL for taxi.is as well? Thank you! :hugs:
@luke, would appreciate if you could also update the TTL for kristjanhall.is… thank you!
Hi, @kristjanhall and @unnursol. Both domains have had the TTL updated now. :slight_smile:
Love you too, @chu. :wink:
