SSL certificate is stuck
I’ve been trying to update my primary domain name and I keep getting the following error: “We’re provisioning a certificate for your site, you cannot change custom domains until that process completes”
This has been going on for a few weeks now. Anything I can do to get past this?
Please and thank you!
Keith
@dudemeister, which Netlify site is this for? (A URL to the site configuration in the Netlify UI or the site’s API ID - not the API Key but the API ID - will allow us to uniquely identify the site.)
Also, would you please confirm that we should remove any/all custom domains from the site in question?
@luke Hi Luke, thank you for the help. Yes you can remove any/all custom domains from the site.
Here’s the API ID: bc08e2cd-dc11-4e22-8614-ae8a7c103a72
Thanks, @dudemeister. All custom domains are now removed. Would you please try adding any custom domains (if any are needed) again now and let us know if there are any further issues?
