Is this correct for the config.yml file?
backend:
repo: drewbacca48/one-click-hugo-cms
backend:
Hi @drewbacca49, it should have proper indentation:
backend:
backend:
branch: default (can this be set to master?)
auth_type: implicit (is there another option so this does not expire in 1 hour?)
Sorry @drewbacca49, I missed on your response.
There are two ways to authenticate with Bitbucket:
The 1 hour expiry is indeed an issue (when using the second method), but the CMS will try to refresh the token silently when it see it expires.
When using the first method the callback in your screenshot is correct.
Which method are you trying to set up?
Thanks and sorry again for the late reply.
