Hi, could you please remove the DNS entries?
I’m fully aware that the site will be offline then.
TTL: 3600 seconds
Type: NETLIFY
Value: unwaste.netlify.com
TTL: 3600 seconds
Type: NETLIFY
TTL: 3600 seconds
Type: NETLIFYv6
Value: unwaste.netlify.app
TTL: 3600 seconds
Type: NETLIFYv6
It would be great if you could mention the impossibility of manually removing those DNS entries for Netlify registered domains in the docs. I was under the impression that once i removed the domains from my site, they would also be removed from DNS. This is not the case. I waited a full hour after removing the domain from my site (because 3600 TTL) only to see it does not work like that.
Thanks a lot!
Till
