Login problem with netlify
I’ve deployed my code successfully and my link worked. But after sometime the link is not working. And also I can’t login. When I’m trying to sign in with github it redirects me to another
page like this. What can I do?
hi there, welcome.
So the screenshot you posted is of you trying to get in touch with the helpdesk, just checking to make sure you are aware.
Can you clarify what problem you are having, exactly? Are you unable to login to netlify.com? If yes, you can use that form but you will need to select “login/signup” for it to be processed correctly.
Let us know if you are still having problems.
