Hi,
I’m trying to protect my specific branch-deploy and deploy-preview based in context using the Basic Auth protection.
The Basic Auth works but when I try to enter to /admin
for use Netlify CMS, the login form not works and the Git Gateway shows: “Git Gateway is not enabled” or “Git Gateway Error: [object Object]” but, if I disable the Basic Auth protection it works correctly.
I don’t know if my headers
configuration are wrong or is a limitation.
[Headers Configuration]
Basic-Auth: user:password
X-Frame-Options: DENY
X-XSS-Protection: 1; mode=block
cache-control: max-age=0
cache-control: no-cache
cache-control: no-store
cache-control: must-revalidate
/static/*
cache-control: public
cache-control: max-age=360000
Any idea for solve it?
