I would like to know that what is the principle of publising my vue project in netlify ?
Because in my git repo there is only the dev-files, but the pub server needs the builded and stripped files.
How is this supposed to be done ?
Hey there!
To deploying a Vue project to Netlify, you can follow these steps:
If you’re using other Vue frameworks like Gridsome or Nuxt, these commands are slightly different. Sarah Drasner from my team wrote up a post about how to deploy various Vue applications that may be handy here
I hope this helps!
Divya
Thank you for your reply! this helps me to understand.
But how about different node+npm versions ? (not the packet versions) thisi gaves frequent build errors that is caused by mismatch node.
How have you solved this ?
Ah, we do have a way to help! You should set a version of node and NPM so that we always use the same one:
