Dear community,
I have tried to deploy my first netlify site but get the following build error:
10:12:25 PM: Build ready to start
10:12:27 PM: build-image version: b0258b965567defc4a2d7e2f2dec2e00c8f73ad6
10:12:27 PM: build-image tag: v3.4.1
10:12:27 PM: buildbot version: 648208d76731cd5bca75c1e9bc99d2032a1f1473
10:12:27 PM: Fetching cached dependencies
10:12:27 PM: Failed to fetch cache, continuing with build
10:12:27 PM: Starting to prepare the repo for build
10:12:28 PM: No cached dependencies found. Cloning fresh repo
10:12:28 PM: git clone https://github.com/LimpingTwerp/allemannia
10:12:34 PM: Preparing Git Reference refs/heads/master
10:12:37 PM: Different build dir detected, going to use the one specified in the Netlify configuration file: ‘’ versus ‘./’ in the Netlify UI
10:12:37 PM: Starting build script
10:12:37 PM: Installing dependencies
10:12:37 PM: Python version set to 2.7
10:12:38 PM: v12.18.0 is already installed.
10:12:39 PM: Now using node v12.18.0 (npm v6.14.4)
10:12:39 PM: Started restoring cached build plugins
10:12:39 PM: Finished restoring cached build plugins
10:12:39 PM: Attempting ruby version 2.7.1, read from environment
10:12:41 PM: Using ruby version 2.7.1
10:12:41 PM: Using PHP version 5.6
10:12:41 PM: 5.2 is already installed.
10:12:41 PM: Using Swift version 5.2
10:12:41 PM: Started restoring cached node modules
10:12:42 PM: Finished restoring cached node modules
10:12:42 PM: Installing NPM modules using NPM version 6.14.4
10:13:04 PM: > core-js@2.6.11 postinstall /opt/build/repo/node_modules/core-js
10:13:04 PM: > node -e “try{require(’./postinstall’)}catch(e){}”
10:13:05 PM: > core-js@3.6.5 postinstall /opt/build/repo/node_modules/vue-slick-carousel/node_modules/core-js
10:13:05 PM: > node -e “try{require(’./postinstall’)}catch(e){}”
10:13:05 PM: > uglifyjs-webpack-plugin@0.4.6 postinstall /opt/build/repo/node_modules/uglifyjs-webpack-plugin
10:13:05 PM: > node lib/post_install.js
10:13:06 PM: npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
10:13:06 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
10:13:06 PM: added 1158 packages from 605 contributors and audited 1229 packages in 23.214s
10:13:07 PM: 27 packages are looking for funding
10:13:07 PM: run npm fund
for details
10:13:07 PM: found 228 vulnerabilities (216 low, 5 moderate, 7 high)
10:13:07 PM: run npm audit fix
to fix them, or npm audit
for details
10:13:07 PM: NPM modules installed
10:13:07 PM: Started restoring cached go cache
10:13:07 PM: Finished restoring cached go cache
10:13:07 PM: go version go1.14.4 linux/amd64
10:13:07 PM: Installing missing commands
10:13:07 PM: Verify run directory
10:13:09 PM:
10:13:09 PM: ┌─────────────────────────────┐
10:13:09 PM: │ Netlify Build │
10:13:09 PM: └─────────────────────────────┘
10:13:09 PM:
10:13:09 PM: ❯ Version
10:13:09 PM: @netlify/build 4.0.4
10:13:09 PM:
10:13:09 PM: ❯ Flags
10:13:09 PM: deployId: 5f6bac2938acbf302936a795
10:13:09 PM: mode: buildbot
10:13:09 PM:
10:13:09 PM: ❯ Current directory
10:13:09 PM: /opt/build/repo
10:13:09 PM:
10:13:09 PM: ❯ Config file
10:13:09 PM: No config file was defined: using default values.
10:13:09 PM:
10:13:09 PM: ❯ Context
10:13:09 PM: production
10:13:09 PM:
10:13:09 PM: ┌───────────────────────────────────┐
10:13:09 PM: │ 1. Build command from Netlify app │
10:13:09 PM: └───────────────────────────────────┘
10:13:09 PM:
10:13:09 PM: $ npm run build
10:13:09 PM: > allemannia@1.0.0 build /opt/build/repo
10:13:09 PM: > cross-env NODE_ENV=production webpack --progress --hide-modules
10:13:10 PM: 0% compiling
10:13:10 PM: 10% building modules 0/1 modules 1 active …/index.js!/opt/build/repo/src/main.js
10:13:10 PM: 10% building modules 1/1 modules 0 active
10:13:10 PM: 10% building modules 1/2 modules 1 active …repo/node_modules/vue/dist/vue.esm.js
10:13:10 PM: 10% building modules 2/2 modules 0 active
10:13:10 PM: 10% building modules 2/3 modules 1 active …s??ref–1!/opt/build/repo/src/App.vue
10:13:10 PM: 10% building modules 2/4 modules 2 active …ode_modules/timers-browserify/main.js
10:13:10 PM: 10% building modules 3/4 modules 1 active …ode_modules/timers-browserify/main.js
10:13:10 PM: 10% building modules 3/5 modules 2 active …uild/repo/src/assets/css/tailwind.css
10:13:10 PM: 10% building modules 4/5 modules 1 active …ode_modules/timers-browserify/main.js
10:13:10 PM: 10% building modules 4/6 modules 2 active …ode_modules/webpack/buildin/global.js
10:13:11 PM: 10% building modules 4/7 modules 3 active …uild/repo/src/assets/css/tailwind.css
10:13:11 PM: 10% building modules 5/7 modules 2 active …uild/repo/src/assets/css/tailwind.css
10:13:11 PM: 10% building modules 5/8 modules 3 active …e-style-loader/lib/addStylesClient.js
10:13:11 PM: 10% building modules 6/8 modules 2 active …e-style-loader/lib/addStylesClient.js
10:13:11 PM: 10% building modules 7/8 modules 1 active …e-style-loader/lib/addStylesClient.js
10:13:11 PM: 10% building modules 7/9 modules 2 active …t&index=0!/opt/build/repo/src/App.vue
10:13:11 PM: 10% building modules 8/9 modules 1 active …e-style-loader/lib/addStylesClient.js
10:13:11 PM: 10% building modules 8/10 modules 2 active …uild/repo/src/assets/css/tailwind.css
10:13:11 PM: 11% building modules 9/10 modules 1 active …e-style-loader/lib/addStylesClient.js
10:13:11 PM: 11% building modules 9/11 modules 2 active …e&index=0!/opt/build/repo/src/App.vue
10:13:11 PM: 11% building modules 10/11 modules 1 active …e-style-loader/lib/addStylesClient.js
10:13:11 PM: 11% building modules 10/12 modules 2 active …uild/repo/src/assets/css/tailwind.css
10:13:11 PM: 11% building modules 10/13 modules 3 active …ue-loader/lib/component-normalizer.js
10:13:11 PM: 11% building modules 11/13 modules 2 active …ue-loader/lib/component-normalizer.js
10:13:11 PM: 11% building modules 11/14 modules 3 active …de_modules/css-loader/lib/css-base.js
10:13:11 PM: 11% building modules 12/14 modules 2 active …de_modules/css-loader/lib/css-base.js
10:13:11 PM: 11% building modules 13/14 modules 1 active …uild/repo/src/assets/css/tailwind.css
10:13:11 PM: 11% building modules 13/15 modules 2 active …/vue-style-loader/lib/listToStyles.js
10:13:11 PM: 11% building modules 13/16 modules 3 active …t/build/repo/src/components/Entry.vue
10:13:11 PM: 11% building modules 13/17 modules 4 active …ild/repo/src/components/HeaderNav.vue
10:13:11 PM: 11% building modules 13/18 modules 5 active …/build/repo/src/components/Slider.vue
10:13:11 PM: 11% building modules 13/19 modules 6 active …ld/repo/src/components/SliderCard.vue
10:13:11 PM: 11% building modules 13/20 modules 7 active …ld/repo/src/components/ImagePlace.vue
10:13:11 PM: 11% building modules 13/21 modules 8 active …/repo/src/components/ProgramMonth.vue
10:13:11 PM: 11% building modules 14/21 modules 7 active …/repo/src/components/ProgramMonth.vue
10:13:11 PM: 11% building modules 15/21 modules 6 active …/repo/src/components/ProgramMonth.vue
10:13:11 PM: 11% building modules 16/21 modules 5 active …/repo/src/components/ProgramMonth.vue
10:13:11 PM: 12% building modules 17/21 modules 4 active …/repo/src/components/ProgramMonth.vue
10:13:11 PM: 12% building modules 18/21 modules 3 active …/repo/src/components/ProgramMonth.vue
10:13:11 PM: 12% building modules 19/21 modules 2 active …/repo/src/components/ProgramMonth.vue
10:13:11 PM: 12% building modules 20/21 modules 1 active …uild/repo/src/assets/css/tailwind.css
10:13:11 PM: 12% building modules 20/22 modules 2 active …_modules/setimmediate/setImmediate.js
10:13:11 PM: 12% building modules 20/23 modules 3 active …t/build/repo/src/components/Entry.vue
10:13:11 PM: 12% building modules 20/24 modules 4 active …t/build/repo/src/components/Entry.vue
10:13:11 PM: 12% building modules 21/24 modules 3 active …t/build/repo/src/components/Entry.vue
10:13:11 PM: 12% building modules 22/24 modules 2 active …_modules/setimmediate/setImmediate.js
10:13:11 PM: 12% building modules 22/25 modules 3 active …/build/repo/src/components/Slider.vue
10:13:11 PM: 12% building modules 22/26 modules 4 active …/build/repo/src/components/Slider.vue
10:13:11 PM: 12% building modules 23/26 modules 3 active …/build/repo/src/components/Slider.vue
10:13:11 PM: 12% building modules 24/26 modules 2 active …_modules/setimmediate/setImmediate.js
10:13:11 PM: 12% building modules 24/27 modules 3 active …ild/repo/src/components/HeaderNav.vue
10:13:11 PM: 12% building modules 24/28 modules 4 active …ild/repo/src/components/HeaderNav.vue
10:13:11 PM: 13% building modules 25/28 modules 3 active …ild/repo/src/components/HeaderNav.vue
10:13:11 PM: 13% building modules 26/28 modules 2 active …_modules/setimmediate/setImmediate.js
10:13:11 PM: 13% building modules 26/29 modules 3 active …ld/repo/src/components/SliderCard.vue
10:13:11 PM: 13% building modules 26/30 modules 4 active …ld/repo/src/components/SliderCard.vue
10:13:11 PM: 13% building modules 27/30 modules 3 active …ld/repo/src/components/SliderCard.vue
10:13:11 PM: 13% building modules 28/30 modules 2 active …_modules/setimmediate/setImmediate.js
10:13:11 PM: 13% building modules 28/31 modules 3 active …ld/repo/src/components/ImagePlace.vue
10:13:11 PM: 13% building modules 28/32 modules 4 active …ld/repo/src/components/ImagePlace.vue
10:13:11 PM: 13% building modules 29/32 modules 3 active …ld/repo/src/components/ImagePlace.vue
10:13:11 PM: 13% building modules 30/32 modules 2 active …_modules/setimmediate/setImmediate.js
10:13:11 PM: 13% building modules 30/33 modules 3 active …/repo/src/components/ProgramMonth.vue
10:13:11 PM: 13% building modules 30/34 modules 4 active …/repo/src/components/ProgramMonth.vue
10:13:11 PM: 13% building modules 31/34 modules 3 active …/repo/src/components/ProgramMonth.vue
10:13:21 PM: 13% building modules 32/34 modules 2 active …_modules/setimmediate/setImmediate.js
10:13:21 PM: 13% building modules 33/34 modules 1 active …_modules/setimmediate/setImmediate.js
10:13:21 PM: 14% building modules 34/34 modules 0 active
10:13:21 PM: 14% building modules 34/35 modules 1 active …-carousel/dist/vue-slick-carousel.css
10:13:21 PM: 14% building modules 35/35 modules 0 active
10:13:21 PM: 14% building modules 35/36 modules 1 active …-carousel/dist/vue-slick-carousel.css
10:13:21 PM: 14% building modules 35/37 modules 2 active …sel/dist/vue-slick-carousel-theme.css
10:13:21 PM: 14% building modules 36/37 modules 1 active …-carousel/dist/vue-slick-carousel.css
10:13:21 PM: 14% building modules 36/38 modules 2 active …sel/dist/vue-slick-carousel-theme.css
10:13:21 PM: 14% building modules 36/39 modules 3 active …uild/repo/src/components/Dropdown.vue
10:13:22 PM: 14% building modules 36/40 modules 4 active …/repo/src/components/HeaderButton.vue
10:13:22 PM: 14% building modules 37/40 modules 3 active …/repo/src/components/HeaderButton.vue
10:13:22 PM: 14% building modules 38/40 modules 2 active …/repo/src/components/HeaderButton.vue
10:13:22 PM: 14% building modules 38/41 modules 3 active …/repo/node_modules/process/browser.js
10:13:22 PM: 14% building modules 39/41 modules 2 active …/repo/node_modules/process/browser.js
10:13:22 PM: 14% building modules 40/41 modules 1 active …/repo/node_modules/process/browser.js
10:13:22 PM: 14% building modules 40/42 modules 2 active …uild/repo/src/components/Dropdown.vue
10:13:22 PM: 14% building modules 40/43 modules 3 active …uild/repo/src/components/Dropdown.vue
10:13:22 PM: 14% building modules 41/43 modules 2 active …uild/repo/src/components/Dropdown.vue
10:13:22 PM: 15% building modules 42/43 modules 1 active …/repo/node_modules/process/browser.js
10:13:22 PM: 15% building modules 42/44 modules 2 active …/repo/src/components/HeaderButton.vue
10:13:22 PM: 15% building modules 43/44 modules 1 active …/repo/node_modules/process/browser.js
10:13:22 PM: 15% building modules 43/45 modules 2 active …/repo/src/components/HeaderButton.vue
10:13:22 PM: 15% building modules 43/46 modules 3 active …/repo/src/components/HeaderButton.vue
10:13:22 PM: 15% building modules 44/46 modules 2 active …/repo/src/components/HeaderButton.vue
10:13:22 PM: 15% building modules 45/46 modules 1 active …/repo/node_modules/process/browser.js
10:13:22 PM: 15% building modules 46/46 modules 0 active
10:13:22 PM: 15% building modules 46/47 modules 1 active …/repo/src/components/HeaderButton.vue
10:13:22 PM: 15% building modules 47/47 modules 0 active
10:13:22 PM: 15% building modules 47/48 modules 1 active …rousel/dist/vue-slick-carousel.umd.js
10:13:22 PM: 15% building modules 47/49 modules 2 active …epo/src/components/OnClickOutside.vue
10:13:22 PM: 15% building modules 47/50 modules 3 active …/build/repo/src/assets/img/Zirkel.svg
10:13:22 PM: 15% building modules 48/50 modules 2 active …/build/repo/src/assets/img/Zirkel.svg
10:13:22 PM: 15% building modules 48/51 modules 3 active …epo/src/components/OnClickOutside.vue
10:13:22 PM: 15% building modules 49/51 modules 2 active …/build/repo/src/assets/img/Zirkel.svg
10:13:22 PM: 16% building modules 50/51 modules 1 active …/build/repo/src/assets/img/Zirkel.svg
10:13:22 PM: 16% building modules 51/51 modules 0 active
10:13:22 PM: 71% sealing
10:13:22 PM: 72% optimizing
10:13:22 PM: 73% basic module optimization
10:13:22 PM: 74% module optimization
10:13:22 PM: 75% advanced module optimization
10:13:22 PM: 76% basic chunk optimization
10:13:22 PM: 77% chunk optimization
10:13:22 PM: 78% advanced chunk optimization
10:13:22 PM: 79% module and chunk tree optimization
10:13:22 PM: 80% chunk modules optimization
10:13:22 PM: 81% advanced chunk modules optimization
10:13:22 PM: 82% module reviving
10:13:22 PM: 83% module order optimization
10:13:22 PM: 84% module id optimization
10:13:22 PM: 85% chunk reviving
10:13:22 PM: 86% chunk order optimization
10:13:22 PM: 87% chunk id optimization
10:13:22 PM: 88% hashing
10:13:22 PM: 89% module assets processing
10:13:22 PM: 90% chunk assets processing
10:13:22 PM: 91% additional chunk assets processing
10:13:22 PM: 92% recording
10:13:23 PM: 91% additional asset processing
10:13:23 PM: 92% chunk asset optimization
10:13:23 PM: 94% asset optimization
10:13:23 PM: 95% emitting
10:13:23 PM: Hash: 1c3ddb27c68b0deeb504
10:13:23 PM: Version: webpack 3.12.0
10:13:23 PM: Time: 14003ms
10:13:23 PM: Asset Size Chunks Chunk Names
10:13:23 PM: Zirkel.svg?db632aa28615334b4e8c473d7d185b05 4.98 kB [emitted]
10:13:23 PM: build.js 1.51 MB 0 [emitted] [big] main
10:13:23 PM: build.js.map 1.94 MB 0 [emitted] main
10:13:23 PM: ERROR in build.js from UglifyJs
10:13:23 PM: Unexpected token: punc (() [src/App.vue:38,0][build.js:560,6]
10:13:24 PM: npm ERR! code ELIFECYCLE
10:13:24 PM: npm ERR! errno 2
10:13:24 PM: npm ERR! allemannia@1.0.0 build: cross-env NODE_ENV=production webpack --progress --hide-modules
10:13:24 PM: npm ERR! Exit status 2
10:13:24 PM: npm ERR! Failed at the allemannia@1.0.0 build script.
10:13:24 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
10:13:24 PM: npm ERR! A complete log of this run can be found in:
10:13:24 PM: npm ERR! /opt/buildhome/.npm/_logs/2020-09-23T20_13_24_110Z-debug.log
10:13:24 PM:
10:13:24 PM: ┌─────────────────────────────┐
10:13:24 PM: │ “build.command” failed │
10:13:24 PM: └─────────────────────────────┘
10:13:24 PM:
10:13:24 PM: Error message
10:13:24 PM: Command failed with exit code 2: npm run build
10:13:24 PM:
10:13:24 PM: Error location
10:13:24 PM: In Build command from Netlify app:
10:13:24 PM: npm run build
10:13:24 PM:
10:13:24 PM: Resolved config
10:13:24 PM: build:
10:13:24 PM: base: /opt/build/repo
10:13:24 PM: command: npm run build
10:13:24 PM: commandOrigin: ui
10:13:24 PM: publish: /opt/build/repo/dist
10:13:24 PM: Caching artifacts
10:13:24 PM: Started saving node modules
10:13:24 PM: Finished saving node modules
10:13:24 PM: Started saving build plugins
10:13:24 PM: Finished saving build plugins
10:13:24 PM: Started saving pip cache
10:13:24 PM: Finished saving pip cache
10:13:24 PM: Started saving emacs cask dependencies
10:13:24 PM: Finished saving emacs cask dependencies
10:13:24 PM: Started saving maven dependencies
10:13:24 PM: Finished saving maven dependencies
10:13:24 PM: Started saving boot dependencies
10:13:24 PM: Finished saving boot dependencies
10:13:24 PM: Started saving go dependencies
10:13:24 PM: Finished saving go dependencies
10:13:27 PM: Error running command: Build script returned non-zero exit code: 2
10:13:27 PM: Failing build: Failed to build site
10:13:27 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2
10:13:27 PM: Finished processing build request in 59.639195772s
Which does not occur when I build the site locally. How would I go about debugging this? (The site is fairly simple)
