Double build for one push?
answered
needs-better-title
#1
Each time I commit I see two builds for the same commit at the exact same time. Is it normal ?
I am using the victor hugo boilerplate (https://github.com/netlify-templates/victor-hugo)
Is it because I have a package.json and Hugo config.toml in the same repo ?
28
#2
Hi @matthieubellon, that’s usually caused by having multiple webhooks or just having a webhook on that site along with the github app. Can you tell us which site you’re seeing this on? Also, can you check the github repo for webhooks to Netlify?
