Deployment Help
I need advice to debug deploy https://app.netlify.com/sites/nifty-joliot-d4d455/deploys/5fffb98a757c67256374969d
I get an error message that reads, " 8:50:25 PM: Build failed due to a user error: Build script returned non-zero exit code: 2". If anyone can point me in the right direction in solving this issue, I’d greatly appreciate it. Thank You
Change your build command to CI= npm run build.
Thank you for your response! Do I have to npm install CI before using it or do I just run CI= npm run build in my terminal?
Nothing before, nothing after. Just CI= npm run build.
Got it. Thank You. The command worked! Thank You once again
