Hey @nzgwynn,
You have some build variables set here:
So it seems like our build system is looking for a directory called “master” that does not exist. Could that be the case? Please also note that the base setting is for a monorepo configuration. If your site isn’t set up that way, you don’t need the base setting at all.
I can’t check out your repo since it’s private, so if you could send your netlify.toml if you’re using one, that would also be helpful. Thanks!
Great, thanks! So first, you should delete the environment variables here:
Just for your reference for the future, you can either set those variables in our UI, as linked above, or in the netlify.toml. The toml will take precedence… unless there’s a “base” set in the UI!
Basically, in this case, it’s just confusing to have both sets, and since you have a toml, let’s just roll with that one. Everything in there looks good to me. Want to delete those things in the UI and then trigger a new deploy here: Netlify App with the “Trigger deploy” button?
