Custom domain www.example.com works OK, but not https://example.com
Hello,
After a lot of doc reading I successfully deployed my JJazzLab Netlify site using my custom domain www.jjazzlab.com. I can access it using http or https, but https://jjazzlab.com does not work.
It triggers a security alert on Firefox. I get a SSL_ERROR_BAD_CERT_DOMAIN error explaining that site uses a certificate not valid for jjazzlab.com, but only valid for the mailconfigovh servers.
I still use the DNS servers from the company OVH (France) who registered my domain.
What should I do ?
Thanks in advance for the help.
Problem solved thanks to the Netlify support, I needed to also add for jjazzlab.com the “A” record pointing to the IP of a Netlify server.
