[Common Issue] I don't see submissions when using javascript
answered
#1
I don’t see submissions when submitting using javascript. What am I doing wrong?
You probably aren’t doing anything “wrong” at all. This is actually a commonly asked question.
Here’s what you need to know: We hate spam about as much as you do.
When you submit via html’s default method, if our spam filtering flags the submission, it will redirect to a recaptcha page where it will wait for a non-robot to check the ‘I am not a robot’ field and this helps prevent spam. Very useful.
However, when you submit via javascript, our system is unable to present the recaptcha page. Don’t worry, we’ve provided a way around this.
You will need to implement what is called a honeypot field. Here’s a little more background on that. You could also give this a read through to learn how to make the honeypot even more effective, if you like!
Since this basically disabled our built-in recaptcha, we provide a couple of ways to implement a recaptcha directly on your form: an explicit recaptcha which is very simple to implement and a fully customizable version.
JavaScript opens up a lot of possibilities. Awesome, right?
Let us know how this worked out! If you have any other questions, comment below!
"Page Not Found" when submitting form
