Hi all.
I’m trying to build my application but not work.
9:55:10 AM: Build ready to start
9:55:42 AM: build-image version: 2dbd444fcdce00cf06325060a8238d5ae3e86774
9:55:42 AM: build-image tag: v3.3.7
9:55:42 AM: buildbot version: 134ec431c6a3ff76e87cc4dc34007fe13842272f
9:55:42 AM: Fetching cached dependencies
9:55:43 AM: Starting to download cache of 169.6MB
9:55:46 AM: Finished downloading cache in 3.469753859s
9:55:46 AM: Starting to extract cache
9:55:56 AM: Finished extracting cache in 10.463283858s
9:55:56 AM: Finished fetching cache in 13.987436454s
9:55:56 AM: Starting to prepare the repo for build
9:55:57 AM: Preparing Git Reference refs/heads/master
9:55:57 AM: Starting build script
9:55:57 AM: Installing dependencies
9:55:58 AM: Started restoring cached node version
9:56:04 AM: Finished restoring cached node version
9:56:05 AM: v10.20.1 is already installed.
9:56:05 AM: Now using node v10.20.1 (npm v6.14.4)
9:56:06 AM: Attempting ruby version 2.6.2, read from environment
9:56:07 AM: Using ruby version 2.6.2
9:56:08 AM: Using PHP version 5.6
9:56:08 AM: Started restoring cached node modules
9:56:08 AM: Finished restoring cached node modules
9:56:08 AM: Started restoring cached go cache
9:56:08 AM: Finished restoring cached go cache
9:56:08 AM: unset GOOS;
9:56:08 AM: unset GOARCH;
9:56:08 AM: export GOROOT=’/opt/buildhome/.gimme/versions/go1.12.linux.amd64’;
9:56:08 AM: export PATH="/opt/buildhome/.gimme/versions/go1.12.linux.amd64/bin:${PATH}";
9:56:08 AM: go version >&2;
9:56:08 AM: export GIMME_ENV=’/opt/buildhome/.gimme/env/go1.12.linux.amd64.env’;
9:56:08 AM: go version go1.12 linux/amd64
9:56:08 AM: Installing missing commands
9:56:08 AM: Verify run directory
9:56:08 AM: Executing user command: npm run build
9:56:09 AM: > frontend@0.1.0 build /opt/build/repo
9:56:09 AM: > react-scripts build
9:56:11 AM: Creating an optimized production build…
9:56:28 AM: Treating warnings as errors because process.env.CI = true.
9:56:28 AM: Most CI servers set it automatically.
9:56:28 AM: Failed to compile.
9:56:28 AM: ./src/pages/Survey/index.js
9:56:28 AM: Line 128:18: ‘setPage’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 129:25: ‘setRowsPerPage’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 143:42: Expected ‘===’ and instead saw ‘==’ eqeqeq
9:56:28 AM: Line 179:23: Expected ‘===’ and instead saw ‘==’ eqeqeq
9:56:28 AM: Line 183:32: Expected ‘===’ and instead saw ‘==’ eqeqeq
9:56:28 AM: Line 222:12: ‘questoes’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 228:23: Expected to return a value in function array-callback-return
9:56:28 AM: ./src/pages/ResponseSurvey/index.js
9:56:28 AM: Line 2:10: ‘Link’ is defined but never used no-unused-vars
9:56:28 AM: Line 12:8: ‘TableContainer’ is defined but never used no-unused-vars
9:56:28 AM: Line 14:8: ‘TablePagination’ is defined but never used no-unused-vars
9:56:28 AM: Line 16:8: ‘Paper’ is defined but never used no-unused-vars
9:56:28 AM: Line 132:18: ‘setPage’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 133:25: ‘setRowsPerPage’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 134:12: ‘selectedValue’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 135:12: ‘linha’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 135:19: ‘setLinha’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 136:12: ‘respostas’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 138:12: ‘ro’ is assigned a value but never used no-unused-vars
9:56:29 AM: failed during stage ‘building site’: Build script returned non-zero exit code: 1
9:56:28 AM: Line 141:11: ‘handleChange’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 148:12: ‘questoes’ is assigned a value but never used no-unused-vars
9:56:28 AM: Line 148:22: ‘setQuestoes’ is assigned a value but never used no-unused-vars
9:56:28 AM: ./src/pages/Logon/index.js
9:56:28 AM: Line 46:50: Expected ‘===’ and instead saw ‘==’ eqeqeq
9:56:28 AM: npm
9:56:29 AM: Shutting down logging, 34 messages pending
