Build failure: script returned non-zero exist code:1
I’m getting build failures when I try to deploy a branch build, starting at 4:38 EST. No changes to any configuration files. The last time it happened this was related to Netlify outages. I see there were some latency issues today according to status.netlify.com. I’ll check back in tomorrow to see if this is the root cause.
Netlify site name: adoring-curran-64ee53
Summary of error:
4:40:02 PM: Finished saving go dependencies
4:40:02 PM: Error running command: Build script returned non-zero exit code: 1
4:40:02 PM: Failing build: Failed to build site
hey there, that’s frustrating that you were having issues - usually build error 1 doesn’t occur when there are system problems like the ones we were having, so there may be a different cause. could you share your full build log please so we can advise?
Hey Perry, I tried another push this AM and things are working normally now and building fine. Not sure why this error occurred. Thanks!
great. glad its working!
